OrbinewbieUK
Mar 27, 2018Aspirant
Conflicting Speed test
Hi all, So connected up my Orbi finally....still looking at creating a backhaul for the second satellite but will do further research on the community. I have a slight concern though regarding d...
Mar 28, 2018Guru - Experienced User
Try using a browwer and speedtest.net, be sure to test different server sites and try different browsers. Seen varied results with different server locations and different browsers. Use a ethernet connected PC to the Orbi router to run speeds test. I would disable or disconnect ALL other devices while speed testing for best accurate results.
