Namdnas
Oct 23, 2016Tutor
Connected Devices displaying differently since update to V1.3.0.12
Before I updated to the new V1.3.0.12 firmware, under "Attached Devices", it would show which devices were connected to the router and which were connected to the satellite. Now, after the update to...
- Nov 13, 2016
Something you can try until it's fixed upstream (advanced users only!):
- Go to the debug page and enable telnet
- Telnet into the router
- Execute the following:
nvram set enable_adv_attached=1 nvram commit
- Exit telnet
- Go to the debug page and disable telnet (please don't forget this step!)
Rodney
peteytesting
Oct 23, 2016Hero
hi
go to
orbilogin.com/debug.htm
tick
Enable advanced view of Attached Devices page
and click save down the botton of the page
close the window and go back to the attached devices list and you will see the better attached devices list
pete
krf007
Oct 24, 2016Star
Thank you. I like being able to see which unit my devices are connected to and used your fix. The fix also shows whether it is 2.4 or 5 which is also nice to know.
