Quickscan
Aug 10, 2020Guide
Connecting Orbi directly into BT ONT
Hi everyone, I've been using Orbi for a couple of years now with a RBR50 router and x2 satellites (very latest firmware all round). Today I moved off cable onto BT (UK ISP) fibre and hoping to get speeds close to 1gb (which I can get via the LAN), but only getting around 350mb via Orbi.
BT supply a SmartHub 2 which is a combined router and wireless box. The thing is, Orbi is already a router so now the signal is going through 2 routers effectively which might be accounting for the perforamce drop. The SmartHub does not have a bridge mode but I have read that I can connect the Orbi direct to the new ONT box BT installed today.
If I simply unplug the Smarthub and connect the ONT direct to the yellow WAN connection on the Orbi its not working, so I'm missing something.
I have read that I might need to change some PPPOE settings but I cant understand why I'd need to do this because both the ONT box and the Orbi are powered off AC.
Can anyone guide me through the settings steps I'd need to take to make this work, as much detail as possible, you can see I'm in the weeds here.
Thanks alot
- MstrbigMaster
Since the ONT is still holding the old router info, you have to reboot or unplug for a minute and plug back in. Then connect the Orbi to the ONT and see if you can install. If not you may have to contact your ISP and give the MAC address to them. WOW networks requires routers to be registered. Not sure about your ISP.
This would be a double NAT (two router) condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
Quickscan wrote:Hi everyone, I've been using Orbi for a couple of years now with a RBR50 router and x2 satellites (very latest firmware all round). Today I moved off cable onto BT (UK ISP) fibre and hoping to get speeds close to 1gb (which I can get via the LAN), but only getting around 350mb via Orbi.
Thanks alot
