melanieharper
Apr 24, 2018Aspirant
Connecting Seagate PersonalCloud to Orbi RBK30
Hi, I have a Seagate 3TB Personal Cloud that I'm trying to connect (wired, no wifi) to my Orbi router. However, it's not showing up on my network. VLAN/Bridge group is enabled due to my ISP's setting...
Apr 24, 2018Guru - Experienced User
Do you have ReadyShare feature on your model Orbi router?
Been some users saying USB drives are not fully supported as of yet.
Something you might contact NG support about on the phone and ask...
melanieharper
A little quick research looks like ReadyShare is possibly not ready for prime time on my Orbi. However, the Seagate personal cloud isn't USB. It's meant to be plugged directly into one of the Orbi's ethernet ports. I've got it plugged and the display light is steady, but the network isn't finding it, and arp -a doesn't show it by MAC address.
I think the VLAN/Bridging required by my ISP may be fudging the issue, as you can't check all ports, and the only free port is the unchecked one. I'd love to call Seagate, but they are closed when I'm off work. Bummer.
