subha_m
Jan 01, 2019Follower
connection not private error in chrome
Hi,
Ever since I installed the ORBI wifi, certain sites on chrome give me a "your connection is not prvate" error. I have checked the system time and date and they are correct. Has anyone else encountered this problem? If so, how to fix it?
Thanks
- JoeCymruVirtuoso
The most common occurrence is going to sites with expired SSL certificates.
Just some suggestions:
First check your anti virus program treatment of SSL certificates. You should be able to liberalize this.
Next go to the Chrome tag settings below.
chrome://flags/#enable-mark-http-as
That should be in the default, which is a neutral setting.
Next go to this community thread and try this fix.
https://community.netgear.com/t5/Orbi/Orbi-Blocking-Websites-Solved/td-p/1677125
What FW is currently loaded?
What is the Mfr and model# of the ISP modem the NG router is connected too?Does this happen with other browsers? Try IE11, FF or Opera...
subha_m wrote:
Hi,
Thanks
