412's avatar
412
Connection/firewall issue
I just switched to fiber. (Htc). Now I can’t log my tv on to internet through Orbi. It is logged on to orbi. There are several sites that are coming up 404 not found. Including orbi downloads.
If I go to the htc modem. Everything works fine. The orbi does not change even if htc modem is turned off. Htc say it is not their equipment. It is a block in the orbi. Says it’s in dmz right now.
HELP
DAN
  • Any progress on this?
    HELP
    DAN
  • FURRYe38's avatar
    What is the Mfr and model# of the ISP modem the NG router is connected too? Built in router here? If so, This would be a double NAT condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
    Couple of options,
    1. Configure the modem for transparent bridge mode. Then use the Orbi router in router mode. You'll need to contact the ISP for help and information in regards to the modem being bridged correctly.
    3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
  • Retired_Member's avatar
    Retired_Member
    How did this happen?  What was involved?
    One of the reasons that can cause such strange -unjustifiable- issue is having double NAT in your network. If your ISP modem is acting as a router and does NATing on the incoming WAN traffic then this can cause different issues since Orbi is also doing NATing. You need to check if you have double NAT.
    Please open a Command Prompt on any computer attached to Orbi and type:
    tracert 8.8.8.8  (or traceroute 8.8.8.8 if you're using a Mac computer)
    1. If you see two private IP addresses listed in the first two hops then you have double NAT. Please check the model of your ISP modem and if you have a manual for it.
    2. If you see only one private address and the second hop shows a public address, then you’re all good and we need then to troubleshoot further to find the root cause of the issue,
  • FURRYe38's avatar
    HELP
    DAN
    • 412's avatar
      412
      Changed to access point. Works great.
