soniczip's avatar
soniczip
Connessione cablata Amplificatore e Diffusore a sistema Orbi WiFi
Salve. E' possibile collegare con cavo un sistema WiFi Orbi [ad esempio RBK23 AC2200] con un amplificatore stereo integrato [ad esempio il mio Cmbridge CXA60] e i suoi relativi diffusori [ad esempio la mia coppia System Audio Mantra 10]? Grazie.
  • I have a SX-1050 RCVR. The best way to connect older non digital equipement to wifi anything would be to find you a RCA to WiFi or BlueTooth adapter or Transmitter.
    soniczip wrote:
    Hi, sorry, I used the wrong example. The stereo amplifier I would like to connect to the Orbi is an old Pioneer Sa-7300 and the speakers are directly connected to it. This would be the set-up for a second room.
    The Cambridge amplifier is in the main room and it's already connected to my iMac with a m2tech hiface two interface converter.
    So, the real question is "can I connect an OLD stereo amplifier to the Orbi WiFi system"?
    Thank you.
  • Cambridge CXA60 is a stereo amplifier. Does it have a LAN port or wifi interface?
    Do the speakers connect wirelessly to the aplifier? Do they connect using Wifi or proprietary radio? Do the speakers have LAN ports?
    • soniczip's avatar
      soniczip
      Thank you.
      • ekhalil's avatar
        ekhalil
        Master
        Yes, why not? Does the aplifier has a LAN port ot wifi interface? But why would you need to connect it to Orbi, what would you get out of that?
