MarkKoops's avatar
MarkKoops
Consistant Packet loss on orbi RBR50
Starting a post since I don't know what to do anymore,
Firmware: V2.7.5.4
Router model: #rbr50 router and 2 satellite
OS: windows and android (I think this is what is being asked?)
environment: direct connection with ethernet cables and WIFI
Since a year ago there has has been constant packet loss which occurs about every second to 2 seconds as seen in the screenshot. Playing online games has been impossible to play competitively for me and brother.
The first thing we tried was restarting everything and after that resetting everything which changed nothing. We have tried changing many settings in the router to no avail. We did some tests to find out what was causing it. When our laptop is connected to the connect box modem we have no issues but when connected to the ORBI rbr50 the problem arises again. Even when connected to the ORBI rbr50 router by cable the issue persists. we swapped our ethernet cables used for this but the exact same issue still persists. We therefore think the issue is within the ORBI rbr50 router but we don't know much about routers and how they work so we are don't know for certain. We also tried disabling the modems 2.4Ghz and 5Ghz features incase it was causing interference but since the issue is there with cables we did not think this would do anything and it did not.
Any suggestion or anyone who knows the cause of the issue at hand please lend your hand.
Kind regards,
Mark,
