Kbomb20's avatar
Kbomb20
Constant lag spikes while gaming on PS4
Hello. I just bought the Orbi RBK50 system and configured it in my house. Everything looks great and I am getting 200-300mb in my basement where I have my satellite. I tried gaming on my PS4 through my WiFi and I’m getting constant lag spikes throughout my entire game. So I switch it up and hardwire my connection to my satellite but I get the same performance. Recently, I had a default router provided by Charter/Specturm that has out performed the Orbi. I didn’t have any lag spikes while playing online.
Can someone please him me to resolve this connection issues to my PS4? If not, I will be returning this item to the store. Thanks.
  • FURRYe38's avatar
    What FW is currently loaded?
    Connect the PS via wired LAN cable. Do you see same problem?
    What is the distance between the router and satellite(s)? 30 feet is recommended in between them to begin with depending upon building materials.
    MIMO, Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Save settings and reboot the router and satellite(s).
    Disney Circle: https://community.netgear.com/t5/Orbi/WARNING-Firmware-2-2-1-210-is-junk/m-p/1667485/highlight/true#M45926
    If you updated to recent FW v.210, try enabling Daisy Chain. Some have mentioned that this seems to be working in reverse order, enabling means disabled actually.
    • Kbomb20's avatar
      Kbomb20
      Firmware: V2.2.1.210
      Modem: Arris TM1602
      ISP: Charter/Specturm 400MB
      I have not see the same problem with my router
      My house is 1999 sqft
      The satellite is in my finished basement while the base unit is on the first floor. They are only about 15-20ft away
      Channel: 2.4Ghz is Auto and 5Ghz is 48
      I can see about 5 other wifi signals
      My router was was new so I do not know what the FW was before I upgraded it.
      I am currently testing out Port Forwarding on my PS4 hoping it will fix the issue as well/
      • Kbomb20's avatar
        Kbomb20
        This is day two using the router and I’ve seen slight quick pauses in streaming PlayStation Vue on my Amazon Fire TV. My Fire TV is about 5 feet away from my base unit.
        I also noticed that I couldn’t hard reset my router yesterday when testing other changes
