barehead's avatar
barehead
Follower
Nov 20, 2017
create subnet for smart home devices on Orbi
I need assist to create a subnet for smart home devices on Orbi (both wired and wife devices such as Roku, Harmony Hub, Echo) that is different from the subnet that we use for phones and PCs. I read the manual, could not find this topic addressed. I created a Guest wifi SSID and have some devices on it, and would like to be have some wired devices (via Orbi physical ports) and those on the Guest wifi to be on one subnet, and phones and PCs on a non-Guest subnet.
  • Orbi doesn't support this type of segregation. I don't think any of the Netgear home routers support this.  This is typically done using VLANs and offered on routers and wireless access points intended for business use.
    • Sparty56884's avatar
      Sparty56884
      I can connect my harmony hub to my protected main network on my Orbi, but am unable to connect it to my guest Network. I also put my Roku, Chromecast, Amazon fire stick on my guest Network. A bit frustrated with that.
