hammadbadozai's avatar
Dec 17, 2019
Crooked Orbi Router. Only solid green power light and can't perform a reset
I have this RBR50K router and i came back home and its not working. I have solid green light at the back however i have been reading multiple tread and almost tried them all.
I did 30 30 30 method, no luck
connected to netgear support, they cant do anything since its not under waranty anymore
I have been trying TFTP method recomended by NG but its not uploading.
I will be very happy if some one would help me in getting this fixed. I dont want to throw my $400 in bin. I purchased a brand new from a guy, i myself opened the box, and it worked fine for a week however after that it just died .
Any help will be appriciated
Thanks
