Pfredd's avatar
Pfredd
Guide
Jul 28, 2018
Daisy Chaining with a CBK40?
It appears that the RBK series of ORBI routers support Daisy Chaining of satelites.
Why is this feature not available on the CBK40?
  • Here is Netgear Support's response to my case regarding the lack of a Satelite Daisy Chaining option:
    We have been informed that the Daisy chain feature is enabled by default and is not a configurable option in GUI. Thank you for letting us know about this. Also, we will forward this to the appropriate team and send a feature request to add this function as a configurable option in the future FW like we have for all other Orbi products.
    • vkdelta's avatar
      vkdelta
      NETGEAR Employee Retired
      Daisy chain is supported. It is enabled by default.
      It does not have option to disable it but the device will auto-adjust between DaisyChain vs Star based on strength of the backhaul links.
      • FURRYe38's avatar
        Thanks for this information. Will keep this in mind.
  • FURRYe38's avatar
    This feature is not available on the CBK40 system. I don't know for sure why. I presume that maybe this system was meant for use with just 1 satellite even though more could be added. Something maybe they might add in the future however only NG knows.
