vannar
Mar 16, 2019Aspirant
Disney Circle installed on Orbi Router-Passcode Problems
I have an orbi router with Disney circle installed on it. I use to be able to login to my Disney circle account on my iPhone.
Now my passcode is not working and when I ask for it to be sent to me, I am not recovering the text.
I would appreciate some help.
Thanks
Thanks
I would post about this here:
https://community.netgear.com/t5/Circle-Smart-Parental-Controls/bd-p/en-home-circle
Thanks - vannarAspirantThan you for your response, but I have read over several threads and tried everything I can do on my end to fix it.
It seems like most people fix this issue by having a moderator help them and get the passcode from the server.
Thanks again!!- FURRYe38Guru - Experienced User
Please post there and I'm sure someone will help you there.
- Blanca_ONETGEAR Employee Retired
- armandobesaAspirantSame issue here. Tried to verify through passcode but always failed. I kept resending and same code keeps failing?
