lookout2015's avatar
Feb 09, 2017
DNS setting doesn't really work
Installed the 3-pack Orbi system yesterday, updated to current firmware (1.4.0.34), reset, then configured and put into use. Overall has worked pretty well but I'm hitting one issue that's becoming a show stopper
My upstream provider is a cable company, so I have a cable modem in front of the Orbi. The DNS supplied by my cable company is broken in various ways (very slow, returns incorrect cached answers, doesn't return NXDOMAIN when a domain doesn't exist, etc) so I normally configure whatever router I have behind the cable modem do DHCP to pull IP address but then configure my own DNS servers
When I configure the Orbi to do this (Advanced settings: IPv6: Use These DNS Servers for IPv6; Setup: Internet Setup: Use These DNS servers for IPv4), and then configure the Orbi to do DHCP for my devices behind it, it does not work correctly. What I see is that they use the Orbi as their DNS (expected) but that the Orbi is relaying DNS to my cable company's broken DNS (what the cable modem got from DHCP) and not to the DNS servers I supplied in the settings (NOT expected)
Is this a known issue? Are there any workarounds or something I'm missing about how to configure this?
  • DarrenM's avatar
    DarrenM
    Sr. NETGEAR Moderator
    Hello lookout2015
    Is there possibly DNS settings in the modem that you are using?
    DarrenM
    • lookout2015's avatar
      lookout2015
      Tutor
      Nope. Nothing configurable in the modem at all -- it just passes what it gets from the ISP
  • What do you have set under Internet setup?  Is that still set to get automatically from ISP?
      lookout2015
      Tutor
      Under Internet
      - IP Address is set to Get Dynamically from ISP
      - Domain Name Server Address is set to Use these
      and then I have a primary and secondary filled out
      I'm also using IPv6 so under Advanced, IPv6, IPv6 Domain Name Server I have Use these set and then a primary and secondary filled out
      • MarkC1024's avatar
        MarkC1024
        Luminary
        Hard to say as I just use what is assigned - haven't really tested setting my own.
