jimpc
Nov 08, 2018Aspirant
Does ethernet backhaul work on FiOS yet?
Stepped away from Orbi for 15 months because ethernet backhaul with FiOS was atrocious. Hopping in to see if there has been any success yet in getting ethernet backhaul to work when the base Orbi is ...
Nov 08, 2018Guru - Experienced User
Orib wired back haul is not dependent upon ISP services. Only that you have good quality LAN cables and if needed use a non managed switch in between the base router and satellites. Manages switches seem to cause problems with Orbi. Users say that if you have a managed switch, you need to disable IGMP Protocols on the switch. Also Green switches seem to cause problems as well.
No issues with my system on wired back haul. All non managed switches and 1 new managed switch with IGMP procotols disabled.
