BruceMacb's avatar
BruceMacb
Does Orbi connect to Testra Gateway HFC
  • hi
    sure as the telstra cable gateway is a router
    so you have 2 options
    ether find out how to bridge the cable modem ( this may be a problem if you use voip for home phone ) and connect the orbi router behind it in auto ip ( ipoe )  mode
    or
    leave the cable modem running as it is as connect the orbi behind it and run the orbi in ap mode
    btw do you have any structures ethernet cabling in your house
    pete
    • BruceMacb's avatar
      BruceMacb
      No Ethernet cablng throughout the hoise - unfortunately. So if I leave the cable running will it effect the stregth of the signal. My initial problem is 2 x concrete walls with steel mesh between the Telstra router and my office.
      • peteytesting's avatar
        peteytesting
        Hero
        no wifi is going to cope with that not even the orbi
        have you looked at power line adapters to get the signal to where its needed
