emmpit
Dec 06, 2020Follower
Does RBR50 Router Support WPA3?
I use an RBR50 Orbi router with firmware updated to latest version 2.71.60. The documentation says that on wireless settings under security you can select WPA3 option, however when I log into the router's settings menu I dont see any such option. In fact the only security options available are:
- None
- WPA2-PSK [AES]
- WPA-PSK [TKIP] + WPA2-PSK [AES]
According to Netgear's documentation WPA3 should be supported. Any help would be appreaciated. Thank you.
5. Under Security Options, select a WPA option:
• WPA2-PSK [AES]
• WPA-PSK [TKIP] + WPA2-PSK [AES]
• WPA3-Personal [SAE]
The WPA3 option uses the newest standard for the strongest security.
Some older computers and WiFi devices cannot use WPA3 or WPA2. If your network includes old computers and WiFi devices, select the WPA-PSK [TKIP] + WPA2-PSK [AES] radio button.===
Said that: What is shown here would be a WPA3-SAE mode _only_ - not supporting any mixed mode (known to cause interoperability issues for many popular wireless client devices - read these fail to associate to the wireless access point).
Have not spotted any indication of WPA3 support in the recent RBR50 firmware release notes however.
Christian_R please provide insight.
- Blanca_ONETGEAR Employee Retired
Hi, All,
Orbi AC device are not compatible with WPA3 security.
Which security features does my Orbi WiFi System support?
Blanca
Community Team- schumakuGuru - Experienced UserTechnically there is nothing stopping Netgear from making WPA3-Personal available on Qualcomm IPQ4019 abgn+ac 2x2:2 (the first WPA3 certified Mesh system was already qualified in 2018 on the very same chipset) as well as Qualcomm QCA9984 an+ac 4x4:4 for the backhaul are supporting it for a long time.
