RedBatman89
Nov 17, 2019Guide
Does the Orbi team have any plans to allow separate SSID in a patch soon?
I'm asking since with some of the latest mesh systems like Google Nest to allow it, will Netgear finally give us the option to seperate 2.4ghz and 5ghz as well?
Very much doubt it. If this is a "deal breaker", I would look elsewhere.
Its not a deal breaker it would be just apreciated since they have fixed ipv6 and made firmware updates not auto update, it only makes since to do this now.
- Retired_Member
RedBatman89 wrote:Its not a deal breaker it would be just apreciated since they have fixed ipv6 and made firmware updates not auto update, it only makes since to do this now.
Are you talking about Netgear?
If so, firmware updates with major revisions are still pushed automatically.
- Ragar99Luminary
Are you sure Google allows separate bands?
"Your Wifi point(s) keeps it simple by automatically choosing the band that gives you the best Wi-Fi."
https://support.google.com/wifi/answer/6293481
If it is just to set up IoT stuff, you don't need to do that.
Forcing certain devices to connect to 2.4ghz - NETGEAR Communities
