BiGMERF
May 08, 2019Apprentice
Double nat issue...
Hey rook here with a quick question...
got a double nat warning on my Xbox one..
running my new Orbi connected to a modem/router combo from century link for my fiber.
So I was doing some research and saw that you can do one of two things to resolve this.
1. Bridge the modem/router. Or
2. Add the Orbi’s ip Address to the modem/router dmz
i chose to do number two
went into my Orbi app to find out the up address. I found it under router settings.
then I signed in to my modem/router and went to the dmz add area. There they have the empty boxes to enter the number, but they also have a drop down box with a list of your devices and their associated ip address. But there the rbr20 is listed under a different IP address.
Which do I use? Do I add the iPad address under router setting in the Orbi app or the one the stock router\modem listing ?
- SW_Prodigy
BiGMERF, assuming you don't need Disney Circle or Armor features, there is a 3rd option, Orbi AP mode, which doesn't require you to tinker with your modem/router settings. Putting the Orbi in AP mode will also shield it from external attacks, i.e., ports scan/sync attacks.
- BiGMERFApprentice
yes thank you, I am aware of AP mode.. only issue with that is you loos some features in the process... it also seemed like for some reason while in AP mode my devices where less likely to connect to the sattelites...
- Kneby2Aspirant
Hi,
Rookie my self, and did the same experience 1-2 weeks ago, when i got my RBR20 + sat.
I did it from the modem(router).
The adress ORBI showed was the WAN adress.
In my modem the orbi was assigned a LAN adress, which i put into the DMZ.
- SW_Prodigy
Just a data point. An example of the type of regular attacks on my RT-AC87U router. Fortunately, both username/password can be changed on this router, which isn't the case with Orbi. The risk with Orbi in Router mode is a bit higer than AP mode setup b/c the default "admin" username can't easily be changed for example. WIth that said, it doesn't mean that Orbi in Router mode isn't safe!
Apr 21 17:14:10 httpd_login_lock: Detect abnormal logins at 5 times. The newest one was from 200.107.254.70 in login.
Apr 22 16:50:31 httpd_login_lock: Detect abnormal logins at 5 times. The newest one was from 200.107.254.70 in login.
Apr 23 07:07:17 httpd_login_lock: Detect abnormal logins at 5 times. The newest one was from 200.107.254.70 in login.
Apr 24 10:16:29 httpd_login_lock: Detect abnormal logins at 5 times. The newest one was from 200.107.254.70 in login.
Apr 24 15:11:14 httpd_login_lock: Detect abnormal logins at 5 times. The newest one was from 200.107.254.70 in login.
Apr 25 00:40:14 httpd_login_lock: Detect abnormal logins at 5 times. The newest one was from 200.107.254.70 in login.
Apr 25 14:52:05 httpd_login_lock: Detect abnormal logins at 5 times. The newest one was from 200.107.254.70 in login.
Apr 25 19:26:05 httpd_login_lock: Detect abnormal logins at 5 times. The newest one was from 200.107.254.70 in login.
Apr 26 05:08:07 httpd_login_lock: Detect abnormal logins at 5 times. The newest one was from 200.107.254.70 in login.
Apr 27 23:33:30 httpd_login_lock: Detect abnormal logins at 5 times. The newest one was from 200.107.254.70 in login.
Apr 28 04:21:26 httpd_login_lock: Detect abnormal logins at 5 times. The newest one was from 200.107.254.70 in login.
Apr 29 13:02:51 httpd_login_lock: Detect abnormal logins at 5 times. The newest one was from 200.107.254.70 in login.
Apr 29 17:40:36 httpd_login_lock: Detect abnormal logins at 5 times. The newest one was from 200.107.254.70 in login.
Apr 29 22:25:29 httpd_login_lock: Detect abnormal logins at 5 times. The newest one was from 200.107.254.70 in login.
Apr 30 03:04:12 httpd_login_lock: Detect abnormal logins at 5 times. The newest one was from 200.107.254.70 in login.
...May 8 05:02:40 httpd_login_lock: Detect abnormal logins at 5 times. The newest one was from 200.107.254.70 in login.
May 8 09:11:50 httpd_login_lock: Detect abnormal logins at 5 times. The newest one was from 200.107.254.70 in login.
May 8 19:54:31 httpd_login_lock: Detect abnormal logins at 5 times. The newest one was from 200.116.170.72 in login.
May 8 19:59:16 HTTP_login: Detect abnormal logins at 5 times. The newest one was from 200.107.254.70 in auth check.
Modem Combo Units:
This would be a double NAT condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
1. Configure the modem for transparent bridge mode. Then use the Orbi router in router mode. You'll need to contact the ISP for help and information in regards to the modem being bridged correctly.
2. If you can't bridge the modem, disable ALL wifi radios on the modem, configure the modems DMZ or IP Pass-Through for the IP address the Orbi router gets from the modem. Then you can use the Orbi router in Router mode.
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktopOption #2 is recommended if you want to use the Orbi in router mode connected to a router upstream from the Orbi system.
- ekhalilMaster
BiGMERF wrote:
............., but they also have a drop down box with a list of your devices and their associated ip address. But there the rbr20 is listed under a different IP address.
Please use the address that you find in the drop down menu for the DMZ settings. This is the address for Orbi in the ISP Router.
- BiGMERFApprenticeOk thank you. I did it and it seemed to fix the issue at least on my Xbox. When I run a cmd check. Two ip’s still pop up.
Also whenever I try to use remote connection via my cell phone outside of my home network. I get that it’s not currently online. It I know it is. Any ideas ?- gr8shoVirtuosoRemote connection has to be enabled via the management console. It hasn’t worked for me in the past 2 firmware updates. .32 and now .44
So why don't you two start a new thread here:
https://community.netgear.com/t5/NETGEAR-Armor/bd-p/en-home-armor
and discuss the ins and outs of on board router security and lets get back to the subject of BiGMERF as his issue has been resolved. :smileywink:
Thank you.
- gr8shoVirtuosoBecause I don't want to talk about Armor, I want to talk about Orbi as a base product. And if we successfully get our Orbi router properly bridged to the Internet, we'd want to know it's safe and secure as is. If I misunderstood the intended purpose of this product, apologies.
Please a new post then. :smileywink:
- Spartacus618Aspirant
Issue with Double Nat on the Xbox. Addressed it with Port Forwarding - quick fix. Hope it helps anyone who comes across if the same issue.
read through the dialog... port forwarding addressed the issue for me but was not tried here.
