siquenique
Sep 25, 2022Aspirant
Drop on speed with rbs40v
I am having issues with speed when connected to the RBS40V. My setup has the router, a rbs20 satellite connected to the router and a RBS40V connected to the satelitte in daisy chain. All the option I saw as recommendation are on. I have the latest firmware in all, does anyone knows how to fix it? If I am next to the router or the rbs20 I get around 230 if I move to the rbs40 I get 112. This one is just right above the rbs20
what speed do you get hardwired into the RBS40V?
That'll be the key as that'll tell you what speeds you're getting out of the backhaul.
- siqueniqueAspirantHow can I check that?
hardwire a pc/laptop into the RBS40V and run a speedtest on the hardwired device
