Andrew1977
Jan 14, 2019Guide
Dropped WiFi calls on iPhone X iOS 12 ATT with Orbi RBR50
I’m experiencing dropped WiFi calls with my iPhone X. The calls will typically last only a few seconds before the call fails. I had been using the WiFi calling on my Orbi RBR50 and 1 satellite for over a year with no problems.
I believe the issue is related to iOS 12 and Orbi since I do not have any WiFi calling issues when I connect my iPhone to the WiFi service on my ATT Uverse router and I can make WiFi calls on other networks away from my home. Maybe I need to adjust a setting in Orbi that did not require that setting prior to iOS 12.
I have tried the following with no resolution:
- Reset and wiped my iPhone
- Current version of Orbi firmware is: 2.2.1.210 and tried rolling back to several different versions of firmware and calls are still dropped
- Put iPhone in airplane mode and tested calls
- Skype calls work fine
- Not using any parental controls and I have not changed any settings in Orbi since intial setup over a year ago, only firmware upgrades have happened which is why I did try several older versions of firmware.
- Orbi sits in DMZ of ATT Uverse router. I had ATT technician onsite to check everything and they found no issues
- Tried disabling SIP ALG setting based on threads I found in Orbi boards here on Netgear. Also tried setting NAT Filtering to “open” from secure.
Does anyone know of a fix for this?
Thanks,
Andrew
The wifi on the ISP modem is disabled?
What is the distance between the router and satellite(s)? 30 feet is recommended in between them to begin with depending upon building materials.What channels are you using? Auto? Try setting manual channel 1, 6 or 11 on 2.4Ghz and any unused channel on 5Ghz.
What WPA security modes are you using?Try disabling the following and see:
MIMO, Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Save settings and reboot the router and satellite(s).If you updated to recent FW v.210, try enabling Daisy Chain. Some have mentioned that this seems to be working in reverse order, enabling means disabled actually.
If Skype calls are working and normal phone calls are not, kind of points to possible problem with iOS. I have hear others mention iOS 12 having issue.
checked the items you suggested.
* The ISP WiFi is disabled, I only enabled it to test to see if calls would drop if my iPHone was connected to the ISP WiFi and the calls do not drop on ISP WiFi. This is why I think the issue is some sort of compatablity between iOS 12 and Orbi since my WiFi calls do work fine on other WiFi systems only have issue on Orbi.
I'm using WPA2-PSK (AES)
I have about 20 WiFi neighbors around me, although since WiFi calls work from the ISP WiFi and the 20 WiFi neighbors have been around for the past year I think that can be ruled out unless there is a specific setting in Orbi that might need to be enabled for this many WiFi systems around me.
I set channel to manual on 2.4ghz and changed the channel on 5ghz.
IPv6, MIMO, daisy chain and fast roaming are disabled. MIMO was enabled and I disabled it all the others were already disabled.
I do think it is an iOS 12 with Orbi issue since iOS 12 WiFi calls work on other WiFi systems and it was working with Orbi prior to iOS 12. I lean toward some setting tweak needed in Orbi and I have tried so many with no luck.
- ekhalilMaster- You mentioned that you don’t use any parental control. Have you been using Circle earlier? How did you deactivate it?
- You also mentioned that you tried using wifi calling while phone is in flight mode, can you please confirm that you get same issue in this case as well.
- ekhalilMaster
The only thing that I can think of is that your calls are being disconnected during handovers between:
1. Your router/satellite. The fact that the call drops quickly makes me think that the phone is jumping frequently between router and satellite. Please check this also in the attached devices menu in the Orbi app or in the GUI.
2. 2.4 and 5 GHz bands
3. Orbi and the ISP router wifi if it's enabled
Please check the following things that can contribute to the wifi calling disconnections caused by above roamings:
1. Is the ISP router wifi enabled? Is it using the same SSID as Orbi? Is it using same channels as Orbi?
2. Are the router and satellites close to each other? If they are and you can't get them further from each other then please try reducing the transmit power of the bands in the advanced wireless settings in Orbi
3. The issue can also be the change in IOS regarding 802.11r standard. Is "fast roaming" enabled in wireless advanced settings?
Thanks for the reply.
I checked the items you listed below and I still have the call drop issue.
1 - my phone is not jumping between the router and satellite. It connects to 5ghz on Satellite and maintains consistent connection never even dropping to 2.4 ghz.
2 - phone consistently connects to 5ghz, never uses 2.4ghz during the times I monitor it.
3 - ISP Router WiFi is turned off. I only enabled it to test and see if my calls would drop while connected to ISP WiFi and the calls never drop on that WiFi.
The router and satellite are about 25 feet from each other with several walls in between. Their locations have not changed in the last year since I have had the Orbi.
I do not have "fast roaming" enabled.
1 - my phone is not jumping between the router and satellite. It connects to 5ghz on Satellite and maintains consistent connection never even dropping to 2.4 ghz. Turn off the satellite(s). Test the phone connected to the base router by itself. Any differences seen here?
The router and satellite are about 25 feet from each other with several walls in between. Their locations have not changed in the last year since I have had the Orbi. 25 feet is a bit too close. 30 feet is recommended in between them to begin with depending upon building materials.
- ekhalilMaster
Andrew1977 wrote:
- ......Orbi sits in DMZ of ATT Uverse router. I had ATT technician onsite to check everything and they found no issues.........
For the sake of testing only, have you tried to remove the DMZ routing and see if that has something to do with your issue?
It's worth testing, although that you can't keep this setting as this will cause double routing and double NAT in your network.
What is the model of the router? there is may be a way to bridge the router instead.
