Dorkapotomus's avatar
Dorkapotomus
Follower
Apr 22, 2018
Echo multi room doesn’t work when one echo is on the router and one is one the satalite.
Title has the details. Same WiFi network but since one is on the router and one is on the satalite they believe they are on different networks. Any ideas? Is this just a flaw with the echo?
  • FURRYe38's avatar
    What model orbi system do you have?
    What FW is loaded on the orbi system?
    Is the Echo devices working?
  • This works fine for me.
    Three Echo's, two of them connected to different sat's, and the third connected to the router.
    What error are you getting?  Can you use other functions such as 'Drop In' from one to the other etc.?
