WAP
Jan 15, 2018Apprentice
Ethernet Backhaul Best Practices
Two questions/clarifications (1) RBR50 is in AP mode. The RBR50 is connected to the ISP router using the RBR50's yellow WAN port. Going to try ethernet backhaul but wanted to do my homework first....
- Jan 15, 2018A large switch with other devices is fine. I would just try the different combinations until you are happy. I concluded it was working fine only when the satellite showed up in the satellites list and said it was using a wired connection, even after a reboot.
MikeMcr
Jan 15, 2018Guide
Please provide a link to where it says to use the LAN point. The documentation I can find says use the WAN port (also look at the picture). See here: https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point
As it happens, the documentation is wrong anyway, especially when using ethernet backhaul. If you don't connect via the LAN point, it appears to work BUT is not communicating with the satellite properly. The satellite will be missing from the top of the devices list or say disconnected.
