WAP
Jan 15, 2018Apprentice
Ethernet Backhaul Best Practices
Two questions/clarifications (1) RBR50 is in AP mode. The RBR50 is connected to the ISP router using the RBR50's yellow WAN port. Going to try ethernet backhaul but wanted to do my homework first....
- Jan 15, 2018A large switch with other devices is fine. I would just try the different combinations until you are happy. I concluded it was working fine only when the satellite showed up in the satellites list and said it was using a wired connection, even after a reboot.
JMU1998
Jan 15, 2018Luminary
MikeMcr yes I do see it but interestingly whenever I have a power outage or Orbi randomly reboots, the sattalite disappears from the attached list on the Main unit and I have to unplug the Ethernet cable and resync wirelessly and once it is synced I plug the Ethernet cable back and it shows up...it is a pain and now I wonder if this is because what you described.
MikeMcr
Jan 15, 2018Guide
Yes, see here for more info:
https://community.netgear.com/t5/Orbi/Orbi-Satellite-Ethernet-Backhaul-and-other-ethernet-devices/m-p/1473420
