WAP
Jan 15, 2018Apprentice
Ethernet Backhaul Best Practices
Two questions/clarifications (1) RBR50 is in AP mode. The RBR50 is connected to the ISP router using the RBR50's yellow WAN port. Going to try ethernet backhaul but wanted to do my homework first....
- Jan 15, 2018A large switch with other devices is fine. I would just try the different combinations until you are happy. I concluded it was working fine only when the satellite showed up in the satellites list and said it was using a wired connection, even after a reboot.
brenth
Jan 15, 2018Star
Here's this, too...
WAP
http://www.downloads.netgear.com/files/GDC/RBK50/Orbi_UM_EN.pdf
pg 90 of the current user guide says the following:
"To set up the Orbi router as an AP after you set up your Internet connection:
Use an Ethernet cable to connect the Internet port of this router to a LAN port on your
existing router or gateway."
Now I'm even more confused. AP with ethernet WAN or LAN?
