Zorat
Aug 19, 2018Tutor
Ethernet Backhaul is freezing up WiFi completely and kicking everyone off (RBR50) & (RBS50)
I have factory reset these both multiple times. I have tried to originally connect them wirelessly, and then shut off the Satellite, and plug it into ethernet, and then turn it back on. This locks up...
- Aug 19, 2018
Have you tried simply waiting? Recognition of wired backhaul takes minutes, not seconds. It generally takes 5 minutes per satellite for my system to stabilize after starting up each wired satellite one at a time.
One theory is that wiring a satellite causes it to use the same LAN address simultaneously for both wired and wireless interfaces, resulting in the storm you see. But the system eventually figures out that it's wired and shuts off the wireless backhaul. This is just a theory, I don't know whether it's the true explanation.
Aug 19, 2018Guru - Experienced User
You might do a full factory erase on the router and satellites. Disconnnect ALL other LAN devices. Start with just one satellite. Set up the router from scratch, then add the 1 satellite via wireless first. Get the BLUE led on top. Then connect the lan cable getween the satellite and router. Do this while in the same room as the router. Wait 5 minutes for the top led to turn on BLUE. Set up an IP address reservation for the satellite ON the router. Turn OFF and then go place it in the remote location. Turn ON and wait for the top led to turn on BLUE. Check connection here. If good, connect the reast of the LAN devices to the router.
There any network switches in the mix? Mfr and model# if you have one...
Having a wired PC with the router helps with connections to the router while setting things up. If you don't have this connection, use wireless.
Heres how I got my friends 50 series up and running:
https://community.netgear.com/t5/Orbi/Orbi-firmware-update-v2-1-4-16-availability/m-p/1592753/highlight/true#M34020
Others to review:
https://community.netgear.com/t5/Orbi/Rbr50-satellite-to-satellite/m-p/1613750/highlight/true#M38100
https://community.netgear.com/t5/Orbi/OrbiOS-2-1-4-10-kills-Internet-access-if-you-use-Ethernet-back/m-p/1603922/highlight/true#M35521
Another initial setup process: https://community.netgear.com/t5/Orbi/Backhaul-breaks-the-whole-network/m-p/1615770/highlight/true#M38393
wabyrd
Aug 19, 2018Tutor
I'm having the same problem. If I plug in one satellite with ethernet backhaul, it will eventually realize it's supposed to be wired and it will work. But once I plug in the 2nd satellite, it all goes down and never recovers.
Nice idea. I just don't think Netgear has it ready for prime time yet. Although, I will say that it is better than Asus's AIMesh which is a total disaster.
