StanM
Nov 28, 2017Aspirant
Ethernet ports active when Orbi is set as Access Point?
My cable modem and router (separate devices) are located in the basement. Ethernet lines are run from the router to various rooms throughout the house. I would like to install the Orbi system upstairs using one of these router's ports (instead of connecting directly to the modem). I read that this can be done by configuring the Orbi as an access point. Can anyone confirm? Also, when setup as an access point, are the wired ethernet ports on the Orbi still active?
Thanks for the quick reply! I already ordered the Orbi system and I'm considering which installation option is easiest while still providing good coverage. This helps alot. Thanks.
- st_shawMaster
Yes and Yes.
However, a collection of wireless access points might be a better solution if you already have Ethernet wiring throughout the house. Something like the Netgear Insight.
- StanMAspirant
- StanMAspirant
A followup question, please: When connecting the Orbi base to the existing router do I use the Orbi WAN input or one of the Orbi ethernet ports?
- st_shawMaster
You must connect Orbi to your router using the Yellow Internet port, not one of the LAN ports. Otherwise, Orbi will light up magenta and think there is no Internet connection.
