Kssmith's avatar
Kssmith
Follower
Jun 20, 2019
Expandable WIFI area
When I bought the router and satalite it  stated it could be expanded up to 4.  Can you buy additional satalites or will it connect to another router and its satalite?\
Thanks,
Kevin
  • Additional satellite(s)s of the same/similar type/WiFi technology level and the outdoor satellite(s) only. Another Orbi router or Orbi kit can't be added.
  • schumaku's avatar
    schumaku
    • CrimpOn's avatar
      CrimpOn
      Exactly right.  If you purchase another "kit", the router cannot be used as a satellite.  There are other possible uses for it, such as an Access Point with a different WiFi name, sell it, or give it to someone.
