numzie77's avatar
Dec 26, 2022
Extra satellite for RBK40
Hi
I have an RBK40 setup (RBR40 router and RBS40 satellite).
I would like another satellite, as we struggle a bit in the end of our house even though it's not that big.
Which satellites (besides RBS40) are compatible for this?
I just need a cheap solution, not a fancy one with a large capacity.
And: Can I hook up another RBR40 on the same network and just let it work as a satellite?
Regards
Kenneth
  • CrimpOn's avatar
    CrimpOn
    Satellites compatible with the RBR40 router include:
    • RBS50
    • RBS40
    • RBS30
    • RBS40V
    None of the AX or "Pro" satellites integrate with the original WiFi5 systems.
  • plemans's avatar
    How big is the home?
    What are the interior walls made from?
    How do you have the router/satellites laid out in the home?
    • numzie77's avatar
      numzie77
      Guide
      It's 155 m2 - aerated concrete walls.
      The router is pretty much in the middle. The satellite is next to the kids computer (wired to his computer).
      But I consider switching to Google Wifi instead. I can get a 3 pcs set used for less than a used satellite - and these firmware update troubles are not keeping me to the Orbi product 🙂
      • plemans's avatar
        ahh, concrete, the bane of wifi existence.
        If you're wanting decent coverage, check into figuring out a way to hardwire in the satellites. Regardless if you switch to google or whatever mesh system you use. The Concrete does a great job of blocking wifi and the mesh systems that use a wireless backhaul are going to struggle because their backhaul gets blocked with the concrete.
        You could look at using powerline, moca adapters, or even just connecting via ethernet if you have it ran through the home.
        (hint, look on amazon at rbk43 renewed. Super cheap and gives you 2x satellites plus a backup router in case yours fails)
