Djzgfx's avatar
Djzgfx
Tutor
Dec 28, 2017
Facebook and Instagram Intermittent Loading
Hello, I’m having the exact same problem on my mobile devices as this post that got zero comments https://community.netgear.com/t5/Nighthawk-WiFi-Routers/Problems-with-Facebook-and-Instagram/td-p/497161
I’m on the latest firmware, even tried 2 revisions older and also tried Advanced Tomato firmware. Nothing helps or fixes this issue. Don’t have any problems while using the trashy arris.
Other than Facebook and Instagram not loading at times, Speedtests are phenomenal and don’t have any other issues at all.
Tried with WMM off/QoS on, QoS off/WMM off, QoS on/WMM on, and QoS off/WMM on. Nothing is helping.
Note: All devices are on 5ghz band
  • I was having these same issues. However, disabling IPv6 wasn't an option as I needed that turned on for my Nest Protect and other smart home devices to be able to connect. I had custom DNS' configured for both IPv4, and setting it up for IPv6 seemed to resolve it - now everything is loading quite fast.
    I use Cloudflare's 1.1.1.1 DNS service. Whatever DNS service you're using, make sure you're also using their IPv6 addresses, like below.
    The addresses of 1.1.1.1 are:
    • 1.1.1.1
    • 1.0.0.1
    • 2606:4700:4700::1111
    • 2606:4700:4700::1001
    Note that in setting up the IPv6 DNS, in the fields provided in the admin interface for the router - it must be filled out like this:
    field 1: 2606  field 2: 4700  field 3: 4700  field 4: 0  field 5: 1  field 6: 1  field 7: 1  field 8: 1
    Router Firmware Version V2.3.1.60
    • FURRYe38's avatar
      Is your ISP servicing IPv6 natively to your system?
      • 1.1.1.1
      • 1.0.0.1
  • I have a suggestion that I believe worked for me. Issue: Facebook or Instagram struggling to load multiple pictures. Facebook was struggling to load comments.
    My equipment: I have the RBK50-100nar (2 PK - AC3000).
    Possible solution:
    Go to Avanced > Advanced Setup > IPv6 > Internet Connection type Auto, IPv6 Filtering = Open.
    When I have the filtering set to "secured", my problems were present. Now they are working. I had also updated my NTP settings to my current time zone. Not sure if that did anything.
    I can't guarantee this will work for everyone but just wanted to share my experience today in hopes it might help others.
  • I tried multiple things before disabling the whole IPv6. Now it works with out any problem, both FB and IG loads content while connected to wifi (Verizon FIOS).
    • FURRYe38's avatar
      Glad that worked for you. Enjoy. :smileywink:
  • I second the fact that just because Facebook and Instagram do not load at times, while every other URL loads fine and you have Fantastic speeds, your issue is elsewhere.
    What Virus/malware protection are you using? Is it router based or software on your PC?
    I ask because an issue like you are reporting usually ends up being too aggressive protection, and occasionally when a user has more than 1 Anti virus system running.
    Are you using the ISP supplied DNS servers or did you use 3rd party DNS servers?
    • michaelkenward's avatar
      michaelkenward
      This is a very useful pointer. Some reports of reluctant sites have tracked back to just this problem.
      It is also very easy to test the idea. There are various "alternative DNS servers" out there to try.
      If you visit the Netgear support pages:
      Support | NETGEAR
      you can feed in your model number and find the documentation for your hardware.
      Look for a section called something like Internet Basic Settings or just search the thing for "DNS server".
      It may be here in the browser graphical user interface:
      • Basic
      • Internet
