Jokul's avatar
Jokul
Failed to connect google/Apple/etc. website with https
Chome browser failed to work as another ssl certificate returned to browser (the cert is with orbi keywords from 1-2 years ago). Could you please help to figure out how I can stop orbi trying to decrypt network traffic by using man in the middle trick? This happens couple days ago, I reboot/reset, the problem still exists, but not always, like it is working now after reboot..
  • FURRYe38's avatar
    What FW is currently loaded?
    Does IE11, FF or Opera browsers do the same thing?
    • Jokul's avatar
      Jokul
      Hardware Version: RBR50
      Firmware Version: V2.2.1.210
      GUI Language Version: V1.0.0.339
      Operation Mode: Router
      When the problem happen, all device has the problem, iphone, ipad, mac, etc. Failed to see youtube on iPhone, failed to open google on Mac, etc. But website without https can work.
      And when the issue happen, I even can't connect to the router with mobile app, only can connect to router on laptop with ip address.
      • FURRYe38's avatar
  • Symantec Eendpoing Protection Mobile is giving one alert: The hostspot attemped to decrypt secure communications. The hotspot used an unsafe "Captive Portal" technique and attemped to decrypt and relay messages instead of establishing direct encrypted communications.
    I have home and guest network, when I connect to guest netowrk, no problem found, but once I connect back to home network, SEP mobile gaves the alert and automatically connects to VPN for protection. Please help to figure out why my orbi trying to decrypt. Thanks! (attached the alert from SEP Mobile)
    • FURRYe38's avatar
      You'll need to contact Symantec and ask them for help and information regarding this and how there program works with Orbi systems. This maybe a false positive message which there system may not be aware of how the Orbi works and or may need to review there program to ensure it works with Orbi systems.
      Personally I don't run any firewall programs on my PCs behind the Orbi. The Orbi already has a firewall. Only security programs I run is malware bytes and AV.
      Let us know what you find out from Symantec...
      • Jokul's avatar
        Jokul
        I don't think it is Symantec Mobile problem, the alert only happens when all device has connection problem. (The Symantec Mobile only installed on my iPhone.) It might be giving incorrect problem name. The ssl certificate sproofing (man in the middle) is the rootcause that all device can't connect to google/apple services.
  • So, I don't know that this is the issue, but it could be. With certain settings, the Orbi will return its own webpage intead of the one you requested. Some scenarios where this will happen is if you have access control enabled and are using a blocked device, if you have the traffic meter enabed and have reached your quota, if you have blocked sites or services enabled and try to access one, etc. So, I'd check all of those and confirm that none of them are the cause.
    Other than that, could it be something with the Orbi VPN being enabled and somehow interacting in a bad way with the VPN you're using on your device?
