Alanyako's avatar
Alanyako
Finding hard time connecting to internet
The router can’t connect to the internet it’s staying offline Nz Vodafone fibre
    1. What type of model do you use to connect to the fibre?
    2. Is Orbi in Router or AP Mode?
    3. Can you reach to the Orbi web GUI? If yes what do you see under >> ADVANCED >> ADVANCED Home >> Connection Status ?
    • Alanyako's avatar
      Alanyako
      RBK53|Orbi AC3000 Tri-band WiFi System
      That’s the model
      • ekhalil's avatar
        ekhalil
        Master
        That’s the model
        What ISP Modem do you use?
  • FURRYe38's avatar
    Modem Combo Units:
    This would be a double NAT condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
    Couple of options,
    1. Configure the modem for transparent bridge mode. Then use the Orbi router in router mode. You'll need to contact the ISP for help and information in regards to the modem being bridged correctly.
    3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
