Helmy's avatar
Helmy
Initiate
Apr 18, 2020
Firmware for Satellite
I just installed a new satellite. My router and original satellite firmware is v2.5.1.8 but the new one is v2.3.5.30
I checked using net gear website and it says no firmware updates needed.
Do I need to update my new satellite? How to update the individual satellite?
  • Retired_Member's avatar
    Retired_Member
    Usually the firmware numbers are the same across corresponding router and sats
    BTW.   Lots of problems with 2.5.1.8
    you may want to revert those devices to 2.3.5.30.
      Retired_Member
      manual updates is neither recommended or needed
