kawaiikoibito28
Jun 03, 2020Aspirant
Firmware RBR40 2.5.1.16 keep disconnecting and auto update again after downgrade
I had a RBR40 and RBS40 which was working fine ever since I bought it last year. But since yesterday the firmware got auto upgrade to 2.5.1.16 and it had been disconnecting every few mins. I tried to use the belwo telnet trick to force it not to upgrade but it still upgrade back to 2.5.1.16 whenever it detect internet connection (I even pull out the internet line when I do the downgrade so it won't auto upgrade it when I work on the orbi satellite downgrade). I also tried to block the keyboard with fw.updates1.netgear.com, netgear.com and such but it still auto download the firmware again and installed it. I'm really appreciate if someone can help on this because I'm in the mid of Working from Home and the internet is disconnecting every few mins on my remote session and it's really frustrating and feeling helpless. Thanks
1) Launch your favorite web browser and go to <Router IP Address>/debug.htm
2) Login <username> <password> when prompted
3) Check Enable Telnet
4) Start a Telnet session. I use Putty. Enter the <Router IP Address> Telnet is using port 23
5) You can skip this step if you like. I am calling it out for illustration purposes only...
Type nvram show | grep auto_* <ENTER>
You will see a list similar to this:
root@RBR50:/# nvram show | grep auto_
vpn_access_mode=auto
wl_auto_antenna=1
set_auto_agreement=0
orbi_auto_upgrade=1
ipv6_autoConfig_dns_assign=0
ipv6_autoConfig_dns1=
ipv6_autoConfig_dns2=
upnp_enable_autoScan=0
ipv6_auto_dns_assign=0
bas_auto_conn_flag=0
orbi_auto_upg=0
autofw_port0=
ipv6_auto_dns1=
ipv6_auto_dns2=
qos_auto_bandwidth=0
green_enable_autorefresh_status=0
enable_dev_auto_refresh=1
wl_rate=auto
auto_check_for_upgrade=1
auto_update=1
root@RBR50:/# root@RBR50:/#
The 3 configurations highlighted above you will want to update the value from =1 to =0
orbi_auto_upgrade=1
auto_update=1
6) To update run the following commands:
nvram set orbi_auto_upgrade=0 <ENTER> (no spaces after set)
nvram set auto_check_for_upgrade=0 <ENTER> (no spaces after set)
nvram set auto_update=0 <ENTER> (no spaces after set)
7) Type the following commands to confirm the 3 configurations are set to =0
nvram show | grep orbi_auto_upgrade <ENTER>
nvram show | grep auto_check_for_upgrade <ENTER>
nvram show | grep auto_update <ENTER>
8) After you confirmed the 3 configuration values are set to =0 then type nvram commit <ENTER> (this step will save the changes)
9) Type exit to terminate the telnet session
Try a full factory reset on the Orbi system after v16 is loaded. Setup from scratch to see if the system stablizes.
- kawaiikoibito28Aspirant
Let me try to start from scratch tonight if that helps.
Keep us posted...
- madhur77Aspirant
Hi,
I have a RBK50 (RBR50 & RBS50) system and have also been going nuts the last week and a half when my satellite started acting strange with firmware update to 2.5.1.16. The wireless backhaul status kept changing from 5G to 2.4G. Stable for some time and then again disconnects and reconnects to the router and effectively the same cycle kept happening. I did all resets of both router and the satellite, but nothing worked. Then i happened to check for any updates and i found that there was one 2.5.1.32. The following were the bug fixes for the same.
Bug Fixes:
- Fixes the incorrect power setting on the WiFi Transmit Power Control
- Fixes potential issues with the Armor activation
The first bug caught my interest as i felt that it could be the reason for the switching. I updated to this firmware and did a complete reset and set it up from scratch. It been up 12hrs and everything is working stable without any switching. I think we are back to the good old days of correct good bandwidth with these mesh system.
Maybe the RBR40 might also be having the same issue and might be getting an update soon.
Hope this helps. Thanks.
-Maddy
- AlHitmiAspirant
Hello,
Since my last comments, I did nothing but changing the port that was connecting my RBR50 to the main router and somehow that did the trick, my connection been up for almost 24 hours now, with no issue. After I checked I saw that there is indeed a new FW update (2.5.1.32). However, when I checked for an update through my router setting page it is showing no new update available. Given that I have a stable connection now, do you guys think I should manually update to the new FW or do nothing since I have no issue now.
Hitmi
IF you have no issues or problems, it best to keep whats loaded for now. You can manually download v32 FW Files and apply them if you want to. Or just download them and keep them handly for later on. v32 is a minor FW update.
AlHitmi wrote:Hello,
Hitmi
madhur77 wrote:Hi,
Bug Fixes:
-Maddy
Too bad I had to replace mine since I was about to get fired for being offline all the time...
Thanks for the update!
