ekstam1105's avatar
ekstam1105
Firmware update
I bought new RBR50 router. Current Firmware version is 2.2.1.210. While setup, it is showing new firmware version 2.3.5.30. Can I upgrade the firmware?
    Yes.  2.3.5.30 has been out for several months.  Some people report issues and are unhappy.  Many of us updated immediatly and have been quite satisfied.  If it happens that you upgrade the firmware and discover problems, it is possible to "go back".
    I would do it before anything else.
  • CrimpOn's avatar
    CrimpOn
  • Retired_Member's avatar
    Retired_Member
    A couple of other thoughts/questions......
    Is your system working fine now?  If it is, why upgrade?
    Did you read the release notes to the new firmware?  Some updates are fucntional specific.  If what it attemps to fix and you don't use it, why update?
    • Ragar99's avatar
      Ragar99
      Luminary
      Seriously?  Have you heard of Orbi's auto-upgrade feature?  None of the posted ways to block the auto update are bullet proof.  I would love to downgrade to an old Orbi firmware in the V1 series and not have it updated.
      • CrimpOn's avatar
        CrimpOn
        My memory is not perfect, but I have a distinct impression that the upgrade immediately before 2.3.5.30 was the first to give users the choice of  upgrading (or not), and I did upgrade on purpose to 2.3.5.30.  I believe that going back to 2.2.1.210 will immediately cause an upgrade to (whatever the heck that number was).
