PF-Keirtt
Feb 25, 2017Aspirant
Strange Issue - PL1200 (X1 Data Usage)
Everyone, I'm hoping I can have some help with this issue. If found to be correct, it could open up a flaw with Comcast's X1 Gateway and potentially help customers who use their products. About...
JamesGL
Feb 28, 2017Master
Hi PF-Keirtt,
To properly isolate the problem, you can try removing the PL1200 from your network and if possible connect all the devices to your gateway. We just have to verify if it is the PL1200 since the communication between the two powerlines are just for local and should not affect the your bandwidth.
- JamesGLMar 06, 2017Master
Hi PF-Keirtt,
We’d greatly appreciate hearing your feedback letting us know if you need further assistance.
- PF-KeirttMar 06, 2017Aspirant
James,
Thanks for the reply. It has taken me a little longer than expected to get the CAT5 cable that I need. I'm having to run an extended line from upstairs to the gateway downstairs. In addition to that, I'm thinking it'll take a few days of testing to verify data usage. I'll get back to you in the next week or so to let you know of my results. Thanks!!
- aalexandrebetaMar 06, 2017Master
That is why I always prefer eth cable over PLC/WIFI!
