rpcathey's avatar
rpcathey
Flashing Amber on 1 plug in satellite
We have an Orbi Mesh system that we use with a fiber optic internet connection. We have 3 plugin satellites and 1 is flashing amber and we can't get it to do anything else. We did a factory reset on the whole system, and still no luck. The Router & 2 Satelites are working fine. It's possible that the plug in was exposed to moisture, but we aren't positive. I have the sync button, the reset button, factory reset, leaving it unplugged for an entire day. I have a feeling that it's no longer good, and if that's the case I need to find out what other plug in satellites are compatible so I can purchase another plug in satellite. Thanks for your help.
