juankt
Oct 22, 2021Aspirant
Forced Firmware updates BRICKED AP mode
I have the Costco Special RBK753 (AX4200) recent "forced" firmware updates have "bricked" the ability to run them in AP mode. Firmware versions 3 and earlier were perfectly fine and completely flawless but versions 4 are total crap! If I have the configuration set to "router mode" all is well (but I cannot browse devices on my wired network hence my desire to configure them as AP's). however whe i switch them to AP mode the wifi connected devices will work for 20-30 seconds and then drop for 10-15 seconds and before reconnecting. Similarly the sattelites constantly lose connectivity and then re-connect only to lose connectivity. Also the indicator lights on the sattelites are a constant purple.
I have tested and retested this with several wifi clients. Id REALLY like to know how to roll back to firmware version 3 or get firmware that actually works so i don't have to return these now USELESS devices.
- juanktAspirantFyi the crap FIRMWARE that does NOT support AP mode is V4.6.5.14
juankt wrote:
! If I have the configuration set to "router mode" all is well (but I cannot browse devices on my wired network hence my desire to configure them as AP's)I have no magic bullet for the 750 firmware issue. Techniques that work to block firmware updates on the original Orbi models are not available on the 750. But.....
Would like to hear more about the issue with wired devices. These devices are not connected to the Orbi products (router and satellites)? But are instead connected to a router that the Orbi is also connected to? And, it is not convenient to move them to the Orbi system?
If this is the case, then it might be possible to create a static route on that upstream router so that packets intended for devices on the Orbi will know "where to go."
- wwlen1GuideIf you are running in access point mode, then you have another router providing the routing functions.
In that case, you could just block the Netgear sites using the blocking functions on the primary router.- juanktAspirant
Wow I'm amazed at how people do not actually read posts. The principal problem is that Satellites RBS will NOT connect to the Orbi Router RBR via wireless the MINUTE you enable AP mode. My devices that are close (with the most recent firmware) can connect to the router but the router will NOT connect to the satellites. They stay purple.
- juanktAspirant
I have dozens of wired network devices, I need network discovery across those network devices from a WIRELESSLY connected device (ala iPhone) for them to function. Hence moving them to the orbi routing is NOT preferrable. Moreover I have several different IOS apps that access the different wired devices, static routing is not possible for some apps and even if it were would be a nightmare to administer.
Netgear has set up a community forum specifically for the Orbi AX (WiFi 6) products. Most of the people who watch that forum are more likely to have experience with Orbi AX and know how to work it better than those of us who follow this "general Orbi" forum. Might be more likely to find someone who has a solution if the question is posted there:
https://community.netgear.com/t5/Orbi-AX/bd-p/en-home-orbi-axActually all FW versions support AP mode on Orbi AX systems. I just had my 8 series in AP mode for a while, now it's back in router mode. Blocking isn't needed while in AP mode.
Thank you.
- juanktAspirant
Actually the AP mode while it's appears to be supported causes the Satellites to FAIL to connect over wifi. I've tried this with three separate ORBI RBK750 sets. Moreover it's quite easy to repro...
Repro:
- Configure RBR750 in router mode
- Connect to satellites using wifi (standard procedure)
- Update to latest firmware 4.6.5.14
- Move the wired connection to the local network FROM the internet port to one of the Ethernet ports
- While connected wirelessly to satellites login to Router and change to AP mode.
- Wait for router to come back up.
- Both satellites will NEVER connect wirelessly Indicators remain Purple and Router "connected devices" page shows the satellites as "Disconnected"
- wwlen1GuideMove the wired connection to the local network FROM the internet port to one of the Ethernet ports.
That's the problem.
Unlike most other routers where you are expected to do this, the Orbi stays in the internet port.
