JeriD
Dec 07, 2019Star
Forcing Guest SSID to be 2.4
Hi - I have seens lots of posts to talk about how you can manually go into debug mode and setup separate SSID's for various purposes. However, I've been unable to force my Guest network to only suppo...
Dec 07, 2019Guru - Experienced User
What most have had luck with is to turn down the broadcast power on the 5ghz signal during setup or you can try disabling the 5ghz ssid broadcast for setup. Once setup, you can turn it back up/on.
- JeriDDec 07, 2019StarThanks for the suggestions. I will give it a try and report back.
