MCO79
Apr 12, 2020Tutor
FWIW Orbi RBR50 dead after power loss
The symptom is Red blinking power light. The unit was running 2.5.1.8 (latest firmware) so it wasn’t in the middle of an upgrade . It was plugged into a power strip as well. Had to run out to best buy and buy another RBK50 thankfully was in stock. All satellites still work after syncing with the new unit. Looks like I got an RBR50v2. Not sure if it’s better then the original with less RAM n all. Totally weird though! The original unit was less thrm 6 months old. I did try to use the reset button with a paper clip, that did nothing. 🤷🏻♂️
I will say props to the front line helpdesk making the RMA process easy. I’ve been a Netgear fanboy since 2006 and i’ll continue to be !
Sounds like you have a warranty claim. Since your "90 day" are past, you might send a private message to one of the forum moderators (by clicking on their "name", such as Blanca_O ) and relate information needed for the warranty claim, such as your name, email, product serial number, date purchased, etc. Netgear prefers that users not post personal information on the public forum.
After reading articles about how "surge protectors" gradually lose capability as their metal oxide varistors (MOVs) degrade, I put all of my critical networking components on small battery backup units. It allows them to "ride through" all of those very short power outages (seconds) and provides additional surge protection.
Glad Best Buy had something in stock. This is not a time to waiting for Amazon.
- MCO79Tutor
Would that still apply for something that has an external DC power supply? It should regulate output I would think. Great idea anyhow, I'll order a Battery backup unit
Did you try a different power adapter on the original RBR? Power adapters take the hit when power outages happen. The RBR may still be ok, just the power adapter maybe bad...
MCO79 wrote:Would that still apply for something that has an external DC power supply? It should regulate output I would think. Great idea anyhow, I'll order a Battery backup unit
