RIPWAG
Mar 23, 2020Aspirant
GS116 bring all Orbi network internet down
I have an Orbi network with two satallites, which have been in place for two years. I have a Spectrum business cable modem, installed about 3 months ago. I purchased 2 GS116 v2 ProSafe 16 port gigabi...
- Mar 23, 2020
Okay. I'll try to connect the switch with nothing plugged in to it, and see what that does.
Mar 23, 2020Guru - Experienced User
If you have tried both with Orbi and with the ISP modem with this switch, I would presume these switches are faulty or have Green Ethernet features which are not compatible with Orbi systems. These are also managed switch which can be problematic. Besure to disable all IGMP protocols and any green ethernet features on these switches to see if this might help.
If not, find some non managed, non green ethernet switches.
Configuration should be like this:
ISP modem>RBR>swtich
RIPWAG
The box says they are unmanaged.
- FURRYe38Mar 23, 2020Guru - Experienced User
Oops darn search got extra charater. You are right they are unmanaged:
https://www.netgear.com/support/product/GS116v2.aspx
However I do see Green Ethernet:
IEEE 802.3az (Energy Efficient Ethernet)
https://www.netgear.com/images/datasheet/switches/GS105v5_GS108v4_GS116v2.pdf
Seen others have this issue as well with Orbi systems:
https://community.netgear.com/t5/Orbi/switching-requirements-for-ethernet-backhaul/m-p/1653718/highlight/true#M43817
https://community.netgear.com/t5/Orbi/Ready-to-chuck-this-system-through-the-window/m-p/1658470/highlight/false#M44394
https://community.netgear.com/t5/Orbi/Orbi-AC3000-with-Cisco-SG112-24-Switch/m-p/1700690/highlight/true#M51879
https://community.netgear.com/t5/Orbi/Orbi-Netgear-GS908E-100PES-Backhaul-Connection/m-p/1784425/highlight/false#M67633
https://community.netgear.com/t5/Orbi-AX/RBR850-Access-Point-wired-backhaul-amp-security-issues/m-p/1868322/highlight/true#M1498
