tony_ngear
Aug 11, 2018Aspirant
Guest Network Available both Secured and Unsecured.
Just an FYI for other users.
During set up I found an unsecured Guest Network in addition to the secured Guest Network – same SSID (same MAC and IP as well) but no password needed to log on and...
Aug 11, 2018Guru - Experienced User
Was this with Guest Network enabled or disabled?
I didn't see any of this on my friends 50 series when I set this up for him:
tony_ngear
This occurred with the Guest Network enabled with SSID visible. When the Guest Network is not enabled the Unsecured Guest Network is not evident on WiFi (obviously the Secured Guest Network also not available).
