Blair2201
Jun 09, 2020Tutor
Hard wired RBS40 keeps dropping out
in 2017 I bought the RBK40/RBS40 package. For nearly 3 years the system has worked flawlessly. About 6 months ago I installed an home office in the back garden and ran a cat 7 cable to the office where the RBS40 now resides and fully tested the wiring; which has been running comfortably at 350mbps without a hitch.
Last week I started getting drop outs, where the app showed that no signal was being recieved by the RBS40. This is nearly always rectified by re-booting the satellite.
Has anyone experienced the same thing? is there a fix or is it just a case of replacing the RBS40?
Any help would be appreciated.
what firmware is on the rbr and on the rbs?
Have you tried a simple reset and reinstall?
how long is the ethernet run?
do you have more than 1 satellite? any chance of swapping it with another one to test if its truly the satellite or if its the run?
Thanks plemans
RBR40 - v2.5.1.16
RBS40 - v2.5.1.16Have you tried a simple reset and reinstall?
I have unplugged the power on both units and restarted. Which corrects things for a while then the RBR drops out again. It can be online and running fine for 2 days before dropping out.how long is the ethernet run?
15mtrs
I've asked a friend of mine just now and he has agreed with a temp swap.- FURRYe38Guru - Experienced User
Does the RBS drop out when wireless connected?
Is the RBS directly connected to the RBR or is there a switch in the middle?
Please try a factory reset and setup from scratch with the RBR and RBS.
Blair2201 wrote:Thanks plemans
RBR40 - v2.5.1.16
15mtrs
Correction, the main router is an ORBI RBR40.
