elliem
Jan 21, 2020Follower
have not been able to use VPN since we installed orbi
The suggestions say to log in and allow for vpn but I cannot even log into the orbi account bc it says i am not connected . The orbi is used to boost our Fronteir wireless service.
What is the Mfr and model# of the ISP modem the NG router is connected too? Built in router here by chance, If so, This would be a double NAT condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktopLog into the RBR with the RBRs log in credentials, which would be admin and the password would be what ever was set during the setup wizard process. Use a PC or laptop with a web browser to connect to the RBR at orbilogin.com or 192.168.1.1 This account differs from the netgear support account.
Could you please explain which "VPN" was being used before installing the Orbi?
i.e. Was VPN software installed on computers to use when browsing the internet?
Or, was VPN software installed on the Frontier wireless so that you could reach your home computer resources when elsewhere?
Thanks
