SubyBrue
Sep 30, 2019Aspirant
Help Changing Orbi from AP back to Router (Verizon AP mode to Comcast Router)
I have successfully been using my Orbi system (RBK23) in AP mode when I had Verizon and was using their Quantum Gateway (turning off their Wifi and everything going through the Orbi's Wifi in AP mode).
I recently switched to Comcast. And while using their provided modem everything worked fine while the Orbi was still in AP mode.
I wanted to ditch the Comast rental modem and purchased a Netger CM1150V (Cable Modem with Voice support). However, I cannot connect to the Orbi when I plug the Orbi into the cable modem. It still broadcasts a Wifi Signal - however I cannot connect to it (NO INTERNET AVAILABLE is the message I get) and I can't even connect to the Orbi management screen to swap it out of AP mode.
As a temporary fix I've pulled out an 8 year old wifi router and that is allowing me to connect the Orbi still in AP mode.
So do I just need to connect to the Orbi while in AP mode - change it back to Router mode and hope for the best. I still am a bit annoyed that I can't even connect to the management screen without having internet available to it - and with my luck I'm apprehensive it flipping it to Router mode only to have the entire Orbi system get into a state where I can't connect to it.
Any suggestions?
Thanks...
Log into the RBRs web page with a web broswer and navigate to Advanced tab/Advanced Settings/Router_AP mode. Here is where you can select Router mode. Save settings.
- SubyBrueAspirant
I realize it must be that simple but is it normal not to get the remote admin to display or even connect when the Orbi can't connect to the internet?
When the Orbi is in AP mode, it depends on a router being available to provide IP addresses for itself and every other device. The new modem is not a DHCP server, so it does not provide IP addresses. Since you mention "remote admin", are you using a smartphone or tablet to administer the Orbi?
If so, you can open a web browser (not the app) on your WiFi device and connect to "orbilogin.net". The Orbi WiFi is set up to look for that request and connect to the Orbi itself. Then, you can enter the login information, "admin" and the administrative password. Navigate to the Advanced Tab->Advanced Setup-> Router/AP mode. Make the change and the modem will restart and work great.
You are never "locked out". You can always perform a "factory reset" and the Orbi will be ready for a fresh setup.
