voerman's avatar
voerman
Help needed with ORBI issue
Router RBR50 with firmware version V2.5.1.8 and behind a modem in bridge modus
Satelitte RBS50 with wired backhaul (cat7) and firmware V2.5.1.8
Netgear ARMOR is turned on
Since last week I am having issues with my Orbi setup and to date I haven't found a way to solve them. The problems started more or less after an software update. What happens is that the connections are more or less stable during the day but at night the wireless connections stop working. The only solution is restart all parts of the Orbi system the next day. It looks like the connection stops at 23:00 at night but not sure about that. Most of the time the router is still working ok and the satellites are offline for wifi. But sometimes the wifi of the router is stopping as well.
When I look at log files I see that I am getting Dos attacks but someone from my ISP said that could as well point at a security system not working properly. Does anybody know what I can do ?
Hope someone can help
Greets Roderick,
Here is a part of the log file
[DHCP IP: 192.168.1.14] to MAC address 18:b4:30:5e:b0:bf, Wednesday, March 18, 2020 08:00:19
[DoS Attack: ACK Scan] from source: 17.242.176.144, port 5223, Wednesday, March 18, 2020 07:57:51
[DHCP IP: 192.168.1.39] to MAC address 88:63:df:8e:35:8d, Wednesday, March 18, 2020 07:57:36
[WLAN access allowed] from MAC : 88:63:DF:8E:35:8D, Wednesday, March 18, 2020 07:57:31
[Access Control] Device IMAC-6DEALS with MAC address 88:63:DF:8E:35:8D is allowed to access , Wednesday, March 18, 2020 07:57:31
[DoS Attack: ACK Scan] from source: 34.237.198.82, port 11095, Wednesday, March 18, 2020 07:57:26
[DoS Attack: ACK Scan] from source: 3.86.149.151, port 11095, Wednesday, March 18, 2020 07:56:30
[DHCP IP: 192.168.1.26] to MAC address 14:91:82:0a:ce:ed, Wednesday, March 18, 2020 07:56:11
[DoS Attack: ACK Scan] from source: 34.195.152.165, port 11095, Wednesday, March 18, 2020 07:55:56
[WLAN access allowed] from MAC : 14:91:82:0A:CE:ED, Wednesday, March 18, 2020 07:55:40
[Access Control] Device WEMO with MAC address 14:91:82:0A:CE:ED is allowed to access the net, Wednesday, March 18, 2020 07:55:40
[DHCP IP: 192.168.1.26] to MAC address 14:91:82:0a:ce:ed, Wednesday, March 18, 2020 07:55:39
[DoS Attack: ACK Scan] from source: 34.237.198.82, port 11095, Wednesday, March 18, 2020 07:55:26
[DoS Attack: ACK Scan] from source: 3.86.149.151, port 11095, Wednesday, March 18, 2020 07:54:29
[DoS Attack: ACK Scan] from source: 34.195.152.165, port 11095, Wednesday, March 18, 2020 07:53:55
[DoS Attack: ACK Scan] from source: 34.237.198.82, port 11095, Wednesday, March 18, 2020 07:53:25
[DoS Attack: ACK Scan] from source: 3.86.149.151, port 11095, Wednesday, March 18, 2020 07:52:29
[DoS Attack: ACK Scan] from source: 3.80.102.142, port 11095, Wednesday, March 18, 2020 07:51:57
[DoS Attack: ACK Scan] from source: 34.195.152.165, port 11095, Wednesday, March 18, 2020 07:51:55
[DoS Attack: ACK Scan] from source: 34.237.198.82, port 11095, Wednesday, March 18, 2020 07:51:25
[DoS Attack: ACK Scan] from source: 18.207.62.3, port 11095, Wednesday, March 18, 2020 07:51:09
[DoS Attack: ACK Scan] from source: 3.86.149.151, port 11095, Wednesday, March 18, 2020 07:50:29
[DoS Attack: ACK Scan] from source: 3.80.102.142, port 11095, Wednesday, March 18, 2020 07:49:56
[DoS Attack: ACK Scan] from source: 34.195.152.165, port 11095, Wednesday, March 18, 2020 07:49:55
[WLAN access allowed] from MAC : 00:1D:63:04:C1:34, Wednesday, March 18, 2020 07:49:34
[DHCP IP: 192.168.1.15] to MAC address 00:1d:63:04:c1:34, Wednesday, March 18, 2020 07:49:34
[Access Control] Device MIELE-001D63FFFE04C134 with MAC address 00:1D:63:04:C1:34 is allowed, Wednesday, March 18, 2020 07:49:34
[DoS Attack: ACK Scan] from source: 34.237.198.82, port 11095, Wednesday, March 18, 2020 07:49:25
[DoS Attack: ACK Scan] from source: 18.207.62.3, port 11095, Wednesday, March 18, 2020 07:49:09
[WLAN access allowed] from MAC : 24:FC:E5:21:B4:1A, Wednesday, March 18, 2020 07:48:53
[Access Control] Device TIZEN with MAC address 24:FC:E5:21:B4:1A is allowed to access the ne, Wednesday, March 18, 2020 07:48:52
[DHCP IP: 192.168.1.10] to MAC address 24:fc:e5:21:b4:1a, Wednesday, March 18, 2020 07:48:52
[DoS Attack: ACK Scan] from source: 3.86.149.151, port 11095, Wednesday, March 18, 2020 07:48:28
[DHCP IP: 192.168.1.14] to MAC address 18:b4:30:5e:b0:bf, Wednesday, March 18, 2020 07:48:07
[DoS Attack: ACK Scan] from source: 3.80.102.142, port 11095, Wednesday, March 18, 2020 07:47:56
[DoS Attack: ACK Scan] from source: 34.195.152.165, port 11095, Wednesday, March 18, 2020 07:47:54
[WLAN access denied] from MAC : 38:D2:69:C0:1C:CF, Wednesday, March 18, 2020 07:47:54
  • Downgrade. Several people, myself included, have had intermittent connnection issues wuith 2.5.1.8
    • voerman's avatar
      voerman
      Didn’t even know that is possible? How do you manage that?
    • voerman's avatar
      voerman
      I downgraded both satelittes and router to version V2.3.5.30. But still having wifi cut out and the satellites showing up with purple connection (no connection).
      Also tried to disable armor but same result.
      Any other ideas ? Should I downgrade to another version ? Please help
      I consider myself lucky that I am not the guy from Netgear that signed off on a software update that makes wifi unstable just before a period WHERE EVERYBODY IS AT HOME AND NEEDS WIFI!!!!
  • FURRYe38's avatar
    What happens if you disable Armor?
    Did you factory reset the RBR and RBS and setup from scratch after applying v2.5.1.8?
    Use a whois to find out where those IP addresses are coming from.
    Greets Roderick,
    • voerman's avatar
      voerman
      Yes , i can but it was a **bleep** getting it to work. I am first trying the downgrade
      • FURRYe38's avatar
        Next time try a reset after a FW update to see if this helps if you encounter problems.
  • Bought a RBR50 Orbi AC3000 plus a RBS50 Orbi Satelite. Set up both according to instructions and both worked as expected, with a few performance issues. Did not maintain a record of the original FW installed. As the web interface suggested a system upgrade, clicked on it and got an upgrade to v2.5.1.8 both on the router and the satelite. The router wi-fi went into intermittent mode, coming and going every 10 or 20 seconds. The satelite just did not connect any more.
    I downgraded the firmware all the way to 1.4.0.16. Intermittent wi-fi continued on the router. Went up through all the versions of firmware, same results. I only managhed to pair the Satelite when I got back to v.2.5.1.8. Each time, I went through the lengthy process of resetting to factory default and reconfiguring everything. But what with an intermittent wi-fi, it was useless.
    BTW, I do have an ISP router, whose wi-fi has been turned off. My optical fiber network ISP is 240 Mbps nominal (what with Covid-19, sometimes I get 2 to 5 Mbps nowadays). I do have double-NAT, since I need specific addresses on my home network (because I hav IOT devices which would be painful to re-address).
    Have given up and gone back to my previous Router.
    Shall wait until Netgear manages to produce a stable FW version for the RBR50/RBS50.
    • FURRYe38's avatar
      FW may not be the poroblem since you said you've gone thru all the versions and still continue to see problems.
      Did you try AP mode with the Orbi and your ISP router?
      Try AP mode with your NG router you have online now.
      Did you put the RBRs IP address it gets from the ISP router into the ISP routers DMZ? This would help with double NAT issues when you have two routers online the same line.
      Above suggestions working:
      https://community.netgear.com/t5/Orbi/Throttling-Devices-RBK53/m-p/1858561/highlight/true#M81925
      https://community.netgear.com/t5/Orbi/Orbi-model-RBR50-keeps-dropping-connection-during-Zoom-calls/m-p/1874136/highlight/true#M84647
      • Retired_Member's avatar
        Retired_Member
        Once again....you're not reading the OP..
        from the OP..."The problems started more or less after an software update"
