cwjones
Oct 29, 2018Aspirant
Help with Set-up RBK50 - Centurylink Fiber (Eliminate D2100T?)
I'm wanting to try to eliminate the Router that CenturyLink is "renting" to me for $10 a month and instead configure the Orbi to be the router. In reading random postings across the internet, it SOUNDS like it's possible, but I'm not finding an exact "It works!" set of steps.
Has anyone been able to configure their CenturyLink PPoE crudentials and VPN mapping so that it worked? If so, do you have exact steps? Much appreciated! (I've got the RBR50 and 2 satellites).
I would ask the ISP if they support any kind of stand alone modem only on there ISP services. Modem only with out a router is preferred with using external routers.
Modem Combo Units:
Couple of options,
1. Configure the modem for transparent bridge mode. Then use the Orbi router in router mode. You'll need to contact the ISP for help and information in regards to the modem being bridged correctly.
2. If you can't bridge the modem, disable ALL wifi radios on the modem, configure the modems DMZ for the IP address the Orbi router gets from the modem. Then you can use the Orbi router in Router mode.
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. - jical80Aspirant
Were you able to successfully complete this setup?
"Set-up RBK50 - Centurylink Fiber (Eliminate D2100T?)"
- cwjonesAspirant
The majority of the solutions offered appear to not eliminate the CL Router, which was the goal. What I was hoping for was steps 1-10 of how to configure the Orbi Router so as to completely remove the CL Router from the setup (and thus return it to them and not have an additional piece of equipment to blame when things go wrong). I unfortunately don't have the time to be experiementing, which is why I was hoping someone else had figured it out.
I'll re-read in a bit and figure out if maybe I missed the obvious answer.
