Mchain's avatar
Mchain
How do I get devices to connect to satellites?
I have a couple of satelllites.  It appears they are both 5Ghz.  all the devices downstairs still seem to connect to the satellite upstairs.  see the video.  Probably something easy to fix?  Appreciate any advice.
  • Retired_Member's avatar
    Retired_Member
    not clear on what your pic is suppose to show....it looks fine to me
    there is lots of discussion about this topic in here you may want to do a search
    even if you are able to do what you think you want to do, what do you think the gain is?
    • Mchain's avatar
      Mchain
      the sateliites are online as pic shows.  I want the devices nearest the satellite to connect.  So there is a computer and TV that are not connected to the satellite closest to it but rather go 2 floors up and connect there.
        Retired_Member
        ok...do a search....will all of this make things 'faster'?'
  • FURRYe38's avatar
