konagal's avatar
konagal
How do I set up the Orbi RBS50Y after I set up my Orbi RBK53 and one satellite?
I purchased both systems so as to have extended coverage including the RBS50Y for outside coverage. How do I set up the RBS50Y after setting up the RBK53 router and one satellite from that model? Would it be better to set them up both at the same time out of the box? There is no documentation specifically for this topic that I can find
  • There’s no right or wrong way. Simply press the sync button on router and RBS50Y and they’ll synch in a matter of seconds.
  • There’s no right or wrong way. Simply press sync button on your Orbi router and then the RBS50Y and they’ll sync in a matter of seconds.
    • konagal's avatar
      konagal
      I forgot to mention I want to do it in the "Daisy Chain" setup method  with the RBS50Y the first satellite in the chain and the satellite from the RBK53 as the next one. Is there a certain thing I have to do for that? Will it ask me if I want to set it up that way or do I have to specify it in a certain way? So, you're saying just click on the sync button after I set up the router in this method?
      • DarrenM's avatar
        DarrenM
        Sr. NETGEAR Moderator
        Yes just follow the normal setup method and within the settings you enable the daisy chain option.
        DarrenM
