Markinportland
Sep 19, 2016Aspirant
How far away can you place the Orbi Satellite?
I have a detached garage with a guest apartment above. It sits about 80 feet from my existing Comcast modem and Apple router in my 3500 SF house. I have tried two Netgear extenders with poor results....
- Sep 20, 2016
Hello Markinportland
Each unit can cover up to 2000 sq feet this will vary based on your environment. Also later on when we are selling individual satellites you can have up to 3 satellites with the one base.
DarrenM
DarrenM
Sep 20, 2016Sr. NETGEAR Moderator
DarrenM
Markinportland
Sep 20, 2016Aspirant
Hi Darren,
Thanks for the info. I still really need to know if there is a max distance that you can place the satellite? Has NetGear tested this?
- DarrenMSep 20, 2016Sr. NETGEAR Moderator
That really depends on the environment of your area I can not give you a exact number but our satellites do have a LED indicator that lets you know if you are to far away from the base for a good connection to help find how far away you can put the satellite.
DarrenM
- peteytestingSep 27, 2016Hero
Markinportland wrote:Hi Darren,
hi
although there is no way to tell exactly and every situation is different because of the enviornment and construction materials , i di some testing by starting out with the router and sat close and ran some speed tests by transferring a file from one to the other to get a base line max speed and connection
i then moved the sat back 5 meters at a time and tested again , once i got pas 10 meters and a few walls away the throughput across the 5 gig backbone was quite effected and the backbone actually changed to 2.4 gig instead which worked well but at a lower speed
if your garage is made is steel or clad in colorbond type naterial then forget it anyway
so i reacon about 40 to 50 feet apart or there abouts is about the max distance you would wantbefore they start to degrade in signal strength for the back bone
have you considered powerline adapters to get the signal from the house to the garage
pete
- itGeeksSep 28, 2016Apprentice
What is a powerline adapter going to do for the OP? After all there is no support for Eithernet backhaul on the sattlelights though as I keep telling Netgear there should be and needs to be, That would solve situations like this. Netgear please make note of this and add this much needed support for Eithernet backhaul or some of us will have no choice but to turn to the compition that has this support.
- peteytestingSep 28, 2016Hero
powerline adapters would be an alternative to orbi , not to be used with them and please stop with the ethernet thing as its known and is awaiting a resolution in the future TBA
- Greyfox63Jul 22, 2022AspirantI bought the Orbi 750 and 3 satellites my home is 91 feet long so I have my router in middle and one satellite placed at each end of house I also have a garage which is approximately 150 feet across the road from my home and the router and my garage has excellent service also all through my home also has great service. So you can place a satellite 150 feet away from router with great results Orbi
- CrimpOnJul 22, 2022Guru - Experienced User
If you plug a satellite into power in the garage and it gets a "blue ring light" and reports the backhaul link is "good", then yes.
(This is not typically what happens.)
